Air blown out the intake
Old Jan 12, 2019 | 01:39 PM
eimantas's Avatar
Default Air blown out the intake
Hello,
My atv won't start and has air blow out from intake to carb. I have removed the cilynder head and poured water from both valve sides and there were no leaks, I have lined up the tdc on piston l then put the timing (valve) gear to the notch on the cilynder head. So what could possibly be wrong?
Old Jan 13, 2019 | 03:32 AM
Cam timing is fairly "wild" on quads, and being a single there are no other cylinders sucking air in, so they tend to spit a mist out of the bellmouth as they run. You don't notice this until you have a problem and take the airbox off. Look elsewhere for the fault, partly blocked carb, no spark etc.
CrAzYViLaN
Oct 18, 2013 06:02 PM
getagripon
Dec 26, 2009 08:06 PM
19dan1988
Feb 20, 2008 09:33 PM
indi360
Dec 8, 2007 02:11 PM
jetmotoracer
Jul 17, 2007 12:39 PM
