Eton yukon 150cxl won't start
Old Mar 25, 2019 | 08:16 AM
jkolegue's Avatar
Wink Eton yukon 150cxl won't start
Makes a clicking noise when trying to start.
Old Mar 26, 2019 | 03:45 AM
Make sure the battery isn't flat. If it is charged, I use a 12v test lamp. Put one lead to earth and the other on the starter live terminal. Switch on, press starter, if the solenoid clicks once, but the lamp doesn't light, faulty solenoid, if the lamp does light, faulty starter. If the lamp is very dim, probably a bad connection, battery, earth, or solenoid leads. If solenoid buzzes when the start button is pressed bad connection, dud battery or seized starter or engine.
DANVAN
Apr 8, 2021 12:53 PM
DANVAN
Mar 26, 2008 11:09 AM
DQ
Aug 23, 2006 11:11 PM
Adirondack
Jul 9, 2004 01:23 PM
NEMISIS
Aug 4, 2003 02:48 PM
