Help I screwed up!
Old Apr 30, 2019 | 10:13 PM
Eilrahc83's Avatar
Default Help I screwed up!
Was trying to change oil on a Loncin 125 atv. What I thought was the oil drain turned out to have a spring and metal rod piece fly out. I put it back in but now it doesn’t start.... what is this part and how do I fix it??
Update
like many I found out it’s the cam chain tensioner rod but what I don’t get is why won’t it start now. I put it back in without turning it over so it should be like it never came out. I did have the bike on it’s side for a minute so maybe the carb was flooded out?
Old May 1, 2019 | 01:36 AM
Plunger back in first, with plastic tip to top, then spring, then plug. Check for a spark, you may have dislodged a wire, but yes you have probably just flooded it.
Old May 1, 2019 | 10:52 AM
Eilrahc83's Avatar
Roger that. I’ll get back to it tonight after work. Hope to get it going again, it used to run good!
Old May 1, 2019 | 08:58 PM
Eilrahc83's Avatar
I can’t get this turd to fire up. Took the carb apart and cleaned it thoroughly, I have spark. It used to run until the cam tensioner rod came out but I put it right back in. What is going on??
Old May 2, 2019 | 03:31 AM
You may as well check cam timing "just in case", it isn't that big a job. Set the valve clearances while you have the timing marks showing too.
Old May 2, 2019 | 08:48 AM
Eilrahc83's Avatar
I’ll get into it tonight and let you know the results. Appreciate your help!
Old May 2, 2019 | 07:41 PM
Eilrahc83's Avatar
Timing is right, valves look good. I don’t understand why this thing ran good and then just quit working??
bladefl
Apr 2, 2002 09:42 AM
PADZZ
Mar 28, 2002 08:09 PM
iridewarrior
Oct 28, 2001 09:22 PM
RoostKing
Jun 20, 2001 10:09 PM
chrism101
Jun 14, 2000 01:56 PM
