Chinese 110cc no spark
Old Jun 13, 2021 | 12:30 PM
integris's Avatar
Default Chinese 110cc no spark
Hi all,
Many thanks for any help in advance!
I have a Chinese quad with no spark.
I have changed/done the following with known good parts:
- spark plug- CDI
- ignition coil
- voltage regulator
- new wiring harness last year- checked woodruff key - good
The only thing I haven't changed yet is the stator. It's a 2 coil. I haven't tested it either.
I don't understand why I'm still not getting a spark. I have read through many forums but all of the problems seem to be behind one of the parts I already replaced (besides the stator but I doubt that it went bad - they rarely do). I will replace it next - I have one on the way.
Old Jun 14, 2021 | 02:16 AM
Using substitution to fix an ignition problem is a waste of time and money, Always do the tests in the "help diagnose stator" sticky here before substituting anything except the spark plug. Your problem may just be a loose wire or faulty ignition switch, and fault diagnosis would find it. Never fit a new CDI without checking the wires to it anyway, a faulty earth wire would result in it blowing the new CDI too.
Old Jun 20, 2021 | 05:07 PM
integris's Avatar
It was the stator. I replaced it with a new one and I got spark right away.
Mosesmclain
1) Engine problems..
10
Sep 3, 2022 09:45 AM
Thendo86
Oct 19, 2020 12:07 AM
Jamie Ray Sanford
Mar 10, 2019 11:56 AM
MarioA
Mar 30, 2016 09:04 PM
stand on it son
Apr 10, 2013 09:16 AM
