ATV accelerating without giving it gas
Old May 25, 2022 | 08:31 PM
AidenZebra's Avatar
Default ATV accelerating without giving it gas
Whenever I start my ATV, it’ll idle without moving for about 10 seconds and then just randomly take off, it’s not going full speed but still, I adjusted the airflow on the carb when I got it because it was running really bad and backfiring but whenever I tighten the air flow screw, it just makes it go without giving it any gas, when I loosen it, it doesn’t go but runs like ****.
Old May 26, 2022 | 02:31 AM
Clean the carb out and check you have no air leaks on the inlet manifold and the choke works properly. Not sure what you mean by "adjusted the airflow" for setting idle speed you set the throttle stop, either how far the carb slide falls on a slide carb, or the butterfly stop on CD carbs. If you can't get it to idle right with that, on a clean carb, you may have to alter the idle jet adjuster, but care is needed, not too much at a time and remember where you started.
Old May 26, 2022 | 05:42 PM
AidenZebra's Avatar
I adjusted the air/fuel screw is what I meant, the little Phillips screw with the spring on it, I cleaned the carb and checked for any leaks but it’s still accelerating and backfiring, do you know why it could be backfiring also?
Old May 27, 2022 | 01:57 AM
Backfiring can have many causes, mixture not set right, air leak at exhaust where it fits onto head, or timing out, valves or ignition, but ignition timing is normally "fixed" on ATVs.
Old Jun 29, 2022 | 03:50 PM
Meax's Avatar
If it is automatic gearbox, try to adjust clutch. Loose the nut, and unscrew until stops, and turn 1/8 - 1/4 clockwise, and then tight locking nut.
Atvrder
Jul 23, 2019 01:14 PM
frmrrz
Nov 3, 2009 07:02 AM
Evader53
Jan 12, 2009 09:11 AM
Aaron529
Jan 7, 2007 02:35 PM
420rappy
Sep 23, 2005 11:06 PM
