No Power Raytech/Qingdao 110cc
Old Oct 5, 2022 | 10:29 PM
Sethzs85's Avatar
Default No Power Raytech/Qingdao 110cc
I have a 2019 110cc Quad made by Raytech/Qingdao. When I bought it they said they were having issues with the “safety switch” as they referred to it. Anyway, I am getting no power it seems. When I have the key turned on and the brake on the light doesn’t come on and from what I remember from these quads is that the rear brake light will come on when you apply the brake even if the quad isn’t running. When I jump the solenoid it will turn over but it won’t try to start when I press the start button.
My main question is, as you can see in the pictures I posted the wiring harness has a gray wire that I am familiar with in any other units I’ve working on. But I have the red lined up with red, black with black, green with green and I lined up the black/wire wire to the gray wire. I tracked down the gray and it’s the only gray wire in the entire harness and it goes from the key ignition to the alarm box/black box which controls the remote start/stop. I’m just wondering if the gray wire should be lined up with another wire. Thank you so much in advance! I appreciate it!! Please See Pictures!
Kbuchmiller88
Aug 4, 2022 10:32 AM
Andygg
Aug 2, 2022 04:29 PM
ll3ananas
Jun 23, 2020 10:08 PM
Ricky Bennett
May 7, 2020 11:26 AM
Daviddls12
Oct 28, 2015 03:54 PM
