Slow to turn over
Old Dec 19, 2023 | 05:56 PM
Gszezorak's Avatar
Default Slow to turn over
Hi I'm working on a tao tao 125 atv it was brought to me as a basket case it was literally in boxes in pieces because it was taken apart by the owner trying to fix.......I have no idea what. I have replaced every switch, button and wire on this thing and it will not rotate fast enough to start. I've replaced the starter and battery 2 times to be sure it wasn't the issue. I even replaced the engine with a new one but still same problem. I'm at the end of my rope with this and completely at a loss can anyone help? Thank you in advance
Old Dec 20, 2023 | 03:23 AM
It can only be the thick wires from battery to solenoid, to starter, or battery to earths on engine and frame. The terminals need to be clean and tight on all of them. Batteries need to be fully charged too. New ones are not always charged up when you get them.
Old Dec 20, 2023 | 08:08 AM
Gszezorak's Avatar
Thank you for the help but I know for a fact it's not a low battery I've made sure of that I replaced it and fully charged it. As far as earth grounds and battery cables I've been through them also
Old Dec 21, 2023 | 04:25 AM
Remove the spark plug cap and see if the engine spins any faster. This shouldn't make any difference, as you have changed both engine and CDI but worth trying, to eliminate the possibility of the ignition timing being out.
Smitty1234
Aug 9, 2022 02:43 AM
Jonathan Voss
1) Engine problems..
Aug 10, 2018 01:17 PM
dmcelroy02
Mar 28, 2018 07:16 AM
Kanderson7271@gmail.com
Apr 26, 2016 08:58 AM
ajfetterman
Apr 1, 2014 06:09 AM
