Now I have random spark issues
Old Dec 22, 2023 | 05:36 PM
Gszezorak's Avatar
Default Now I have random spark issues
Hello AGAIN ugh!!! Still working on this tao tao 125 quad. My first issue was not spark then solved that by running a ground to the frame where the coil mounts. Second problem slow to turn over like a dead battery but replaced battery 2 times with new one and new starter found bad starter solenoid which was new so went back to old one. Current problem now I have random spark. Only sparks every now and then any ideas anyone????
Old Dec 23, 2023 | 04:07 AM
Change the plug, if that doesn't work do the help diagnose stator tests, in the sticky at the top of this section. A bad earth can wreck the CDI so that is a possibility, but test the stator and coil first, as CDIs are what must be wrong if all the wires to it test out as right.
Gszezorak
1) Engine problems..
Dec 21, 2023 04:25 AM
overall999
Jun 26, 2022 08:19 AM
stuntdogg
10
Sep 14, 2021 12:20 PM
Kcherrix
Dec 17, 2018 09:41 AM
Matt Hall
Sep 19, 2018 05:58 PM
