70cc atv starting issues
Old Dec 30, 2023 | 08:47 AM
j.gruna@icloud.com's Avatar
Default 70cc atv starting issues
Hello all,
I sure am having some issues trying to fix my sons 2021 70cc fox atv. I recently bought and replaced the cylinder head because a screw from the choke on the carb came off and got jammed in one of the valves so that’s where my first issue started. I have new head on, timing chain lined up correctly to the motors dead top on the flywheel. I set the valves to .004. I hooked a battery to the neg on the starter, then a jumper from positive to tap the starter for the motor to start, but all it does is spin the starter and the chain connected to the starter and around the flywheel but won’t spin the flywheel? Is something now wrong with the stator? I’m so frustrated with this motor. Any help would be appreciated.
Old Dec 30, 2023 | 12:12 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Starter clutch sounds like not enaging? Is the starter turning backwards? Did you remove the flywheel?
Old Dec 30, 2023 | 12:32 PM
Where would the starter clutch be? I didn’t do anything with the flywheel. I did buy a new starter but it started before so it should be going the wrong way. If I turn the flywheel by hand, it engages the motor
Old Dec 30, 2023 | 05:09 PM
Loved
Community Favorite
It bolted to the flywheel if old starter work and new one doesnt starter going wrong deiection remove new starter and get old starter and put side by side and
hook battery power to them an watch direction
Old Dec 30, 2023 | 05:12 PM
Loved
Community Favorite
If it has kickstarter on the side could be on it I dont have a parts breakdown sorry try the starter trick first
Old Dec 30, 2023 | 05:20 PM
Loved
Community Favorite
KAYO MOTOR FOX 70 Service Manual (Page 101 of 105) | ManualsLib
Old Dec 30, 2023 | 05:21 PM
Loved
Community Favorite
Here a breakdown and starter clutch
Grrrizzly660
Aug 27, 2020 02:27 AM
megandsb
Technical and How-To Articles
Apr 17, 2020 06:41 PM
kali
1) Engine problems..
Mar 12, 2013 10:45 AM
deziner75
Dec 29, 2011 02:05 PM
brindley
Apr 30, 2007 10:21 PM
