2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Help - how do I correctly reinstall these parts?
Old Mar 24, 2016 | 08:23 PM
ATV_Noob's Avatar
Default Help - how do I correctly reinstall these parts?
As it will soon become apparent, I am an ATV novice. I am changing the oil on my Coolster 110 cc quad for the first time. The manual appeared to indicate that there are two oil drain plugs. The plug in the center was an oil drain plug but the one on the left side was not. When I removed this plug, a spring loaded shaft shot out. Doh!
Please see the attachment named parts.jpg. What are these parts? Part of the transmission? How do I reinstall them correctly? Like what is shown in the attachment named part install order.jpg? Do the holes in the shaft need to be oriented in a particular way?
Attached Thumbnails Help - how do I correctly reinstall these parts?-parts.jpg   Help - how do I correctly reinstall these parts?-part_install_order.jpg
Old Mar 25, 2016 | 09:52 AM
Zrock's Avatar
Super Quad Patrol
yep i make that mistake everytime i do a oil change..LOL... steel shaft - spring - plug... just like your second pic
Old Mar 25, 2016 | 11:16 AM
ATV_Noob's Avatar
Zrock:
Thanks for the info. It happened so fast and I wasn't expecting it so I didn't see the order in which they shot out. After a few choice expletives, I almost installed them in this order but thought I should confirm the order so I didn't damage the engine.
Asaran
Jun 2, 2016 07:24 AM
slowjoe41
Mar 25, 2016 05:37 PM
darrm1
Mar 24, 2016 11:38 AM
SOLOLUCKY
Mar 23, 2016 12:07 PM
Ross.B
Mar 23, 2016 09:28 AM
