2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Front Brake Adjustment
Old Aug 28, 2020 | 05:54 PM
HarryJ's Avatar
Default Front Brake Adjustment
I have a Venom Madix 110 cc which has dual cable activated front drum brakes. I have adjusted one of the cables as far as possible at the lever adjustment screw and also at the cable center connection screw. There is still too much play in the cable to activate the brake properly. Can the cable lever at brake drum be re-positioned on the spline shaft?
Old Aug 29, 2020 | 02:02 AM
Don't know the "Venom Madix 110" but moving the levers onto the next spline is the usual method of taking up play on quads once all cable adjustment has been used up. Eventually the shoes get to sticking on the cams, as the higher they are lifted by them, the less the spring back effect. You then have to fit new shoes, this often occurs well before the linings are worn away.
WAATV
Apr 18, 2007 06:25 PM
Tyrann
Dec 25, 2003 12:50 PM
jeepin
Dec 1, 2000 11:24 PM
robandkc
Jul 21, 1999 03:50 AM
