2) Chassis problems.. If your quad runs but you have other problems.. post in here.
No reverse and slipping feeling in gear
Old May 19, 2024 | 05:53 PM
Desertrat250's Avatar
Default No reverse and slipping feeling in gear
So, two problems:
First, I just purchased this 2005 Loncin 250cc for $300, got it running, and reverse worked fine. I had a little trouble shifting it into reverse a few times, but it eventually slipped into reverse. After a few test drives, the shifter just stops at neutral, halfway between forward and reverse, and won’t shift into reverse. I tried messing with the linkage, but it didn’t solve the problem.
Also, when I drove it around for a little while, I noticed a gear-slipping sensation when driving in gear at lower (maybe quarter) throttle, gears 1-3. When I would punch the throttle, I noticed the slipping sensation much less, if at all. I don’t know if it’s a carburetor thing or a transmission/chain thing, or something else completely. The engine runs really strong and idles great. It hasn’t bogged out once since I got it started, although I haven’t cleaned the carb yet.
Thoughts, anyone? Merryman?
Thank you in advance.
Old May 19, 2024 | 06:48 PM
Update: shifter goes into reverse if I roll the atv backwards a few inches while shifting (weird).
Now, to tackle the other issue of the slipping/jumping/lunging feeling I was trying to describe earlier. No problem shifting into gears or catching once shifted, but after gear engages and holding throttle low and steady.
Old May 20, 2024 | 03:22 AM
Could be your centrifugal clutch slipping. They usually work fine until the shoes wear down to the metal, then they slip. Yours could be just worn out, or the mechanism a bit sticky. As for reverse, it should work OK with engine running, gear dogs need to be moving to go into mesh.
Old May 20, 2024 | 11:36 PM
While riding today, the gears disengaged completely and would not go back into any gear, including reverse. I adjusted the linkage and not only did it go back into gear but it fixed the jerking/slipping while cruising at constant speed. I only drove it for a few minutes until it ran out of gas, but it drove smooth and steady at constant low-speeds all through the gears. It even picks up a little bit quicker.
I’ll gas up and go on a longer ride tomorrow to see if this actually solves the problem.
Old May 20, 2024 | 11:41 PM
I adjusted the linkage from this:
To this:
Zahrticus
Oct 17, 2021 07:59 PM
Gy6help
Jun 2, 2020 01:28 PM
MikeB82781
Jun 20, 2009 10:45 PM
dhelmedach
Feb 28, 2009 03:28 AM
swapy2008
Technical and How-To Articles
Oct 6, 2008 03:56 PM
