Rear axle sleeve question
Old Jul 3, 2011 | 02:05 PM
rbstern's Avatar
Originally Posted by mywifesquad
I understand now...Id go down to your local hardware store and get some large thick washers.. use them as spacers to make up for slightly short sleeves...
Got it. Thanks.
Last question (for now). Do I use grease under those sleeves for rust protection? Or will that just make a mess when dirt gets in there?
Old Jul 3, 2011 | 02:08 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I almost always use a little grease..If you want to be really cool.. get some orings ( 4...2 for each side) that fit over the axle... put 1 on each side of the sleeve and they will keep the grease in and the dust out..
Old Jul 3, 2011 | 05:28 PM
rbstern's Avatar
Thanks again for the guidance.
Neither the local auto parts store nor hardware store had washers with an I.D. big enough for the axle. Ended up using rubber gasketing sheet from the plumbing department. Cut some washers out of the rubber. It's working nicely. I've got the axle back in place, along with the chain, and the quad is back on all fours. I've got a used header from a Honda 200 coming, hoping it will mate up properly to the motor's head. If it fires up, I'll buy a muffler for this thing.
Still to do:
Wire in the regulator
Wire the start/kill switch back in.
Install a battery
Install new rear disc brake pads
Fill/bleed the brake hydraulics
Put in a fuel cutoff valve
Fix the choke cable assembly
Deal with whatever carb issues come up
It's gonna be a bit of a stripper with minimal circuitry just for starting, stopping, and charging the battery, but I figure that's one way to help keep this thing running, by doing away with the potential for electrical faults.
Old Jul 3, 2011 | 09:40 PM
KTM Patrol
Former Chinese POW!
Your Welcome.
Sounds like you got a good plan for the rest of this machines needs..
LynnEdwards will be a lot of help (if needed) with the electrical work.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
