My 200cc Quad will NOT start using the Electric Starter (Video and Pictures Inside!)
Old Jul 9, 2011 | 06:58 PM
King_Loco's Avatar
Angry My 200cc Quad will NOT start using the Electric Starter (Video and Pictures Inside!)
Rigged up my electrical system in a certain way as shown in the video
My main issue is that the quad will not start. I purchased a new spark plug, used some starting fluid, cleaned out the carburetor, and I can almost guarantee their is nothing wrong with the engine.
My guess is that there is an unplugged or loose wire on the quad that is acting as a kill switch since it's not being occupied which is not allowing the engine to get spark.
I've done a lot and I am sure it's something very small that I am not noticing. Please help me fix this for my son!
YouTube VIDEO URL: YouTube - ‪200cc Quad Issue‬‏
Old Jul 9, 2011 | 07:00 PM
King_Loco's Avatar
Accidental Post. My Apologies.
Old Jul 10, 2011 | 08:28 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Other than making sure all the connections are tight.... and taping off exposed wires (so they dont become a ground and kill spark)..
I got nothing,,
Old Jul 10, 2011 | 12:19 PM
King_Loco's Avatar
I remember on my 90cc Baja, if this little plug which you hook a lanyard wasn't plugged in the back, the engine would seem like it is trying to start using the electrical starter but it just wouldn't start. As soon as you plug in that pin, it would start which leads me to believe that this can still be an electrical issue.
Otherwise, it has the be the carbuncular not getting enough gas or needing tuning.
Old Jul 10, 2011 | 01:29 PM
KTM Patrol
Former Chinese POW!
Have you checked for spark?
Old Jul 10, 2011 | 05:54 PM
King_Loco's Avatar
If you can thoroughly explain how to do it, then I can go check.
Old Jul 10, 2011 | 08:42 PM
KTM Patrol
Former Chinese POW!
Pull the spark plug... put it back in the plug wire.. hold the end you screw into the engine up against the cylinder/head and crank the engine... do you see spark? is it blue? this works best in the shade than in direct sunlight.
Old Jul 10, 2011 | 10:17 PM
King_Loco's Avatar
Hey,
I just saw your post now while I was signing on to update this thread on the situation.
I took apart the carburetor and ensured gas was going to the carburetor since it wasn't last time. Then, I tightened up the spark plug a bit as well.
The engine is starting and revving up but quickly dying. This leads me to believe it is not an issue with the spark plug.
My guess is that I need to continually crank the engine and rev it while playing with the throttle and choke.
However, one quick question, not quite sure if it was coincidental or not but it appeared that once I took the wires off of the battery after I got it started, the engine would die? But I do remember taking the wires off and the engine was running fine so that may eliminate this question. I just wanted to ensure if I was one hundred percent sure that the engine was running when I disconnected the wires from the battery.
Normally, once you get the engine started, the electrical system should have nothing to do with it thereafter. Am I mistaken?
My overall diagnosis is that I should charge up all of my batteries using a battery charger then continue to crank the engine since it seems like its just trying to shoot some of the crap out since it has been sitting for a while.
Old Jul 10, 2011 | 10:53 PM
LynnEdwards's Avatar
Electrical Expert
On a properly working quad the battery charging system will still maintain the 12 volt stuff if the battery is disconnected. Thus with a running engine everything should work fine.
If your ignition system is powered off moderately high voltage AC power from the stator, then even if you battery charging system is flat dead the engine will run fine off its own separate ignition power supply.
However, if your charging system isn't working, and your ignition system is powered off 12 volts DC, then if you disconnect the battery the quad will die due to lack of spark.
So I suspect your battery charging system is not working, and your CDI is 12 volt DC powered. You'll need to fix the battery charging system. Batteries that sit around at anything below being fully charged are damaged and quickly ruined.
Old Jul 10, 2011 | 11:07 PM
Electrical Expert
On your first post (the one with all the pictures) I count 9 pictures.
On picture 7 of 9 there is a six pin connector in the center of the picture. I see 2 or maybe 3 pins that look like they have backed out of the connector housing (Blue/White, Black/Red, and Red). Note how the Green/White, and Yellow wires are fully seated in the housing. Those wires that are backed out is a problem since they could be making intermittent contact.
The Black/Red and Blue/White would be the AC Ignition Power, and the Timing trigger pulse to the CDI. Both of these would prevent spark. The red (maybe pink) wire is probably part of the battery charging system. Look at these carefully. This might explain some of your problems.
I also note that the presence of then black/red wire coming out of your stator contradicts my previous post about your CDI possibily being DC powered ...
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
DOAinNY
Jun 11, 2015 10:34 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
