PLEASE HELP!!!! Edge 90 ATV won't start.
Old Aug 21, 2011 | 10:03 PM
Rick - PA's Avatar
Default PLEASE HELP!!!! Edge 90 ATV won't start.
Hello forum!
I'm Rick.
Please I need help, I just got this quad from my neighbor because he wanted to clear out his garage. I can't get it started, this is what happens when i try:
1 - When i press the start button it clicks and it sounds like electricity is going tru and nothing else. I checked the spark plug and no spark and it's a new one.
What could be wrong???
Old Aug 21, 2011 | 11:16 PM
LynnEdwards's Avatar
Electrical Expert
Jump the quad battery to your car using jumper cables. Use extra care to get the polarity right - positive to positive, and negative to negative... Try to start the quad. Any change?
Do you have a meter? What is the DC voltage on the quad battery while you are attempting to crank the quad (i.e. the solenoid is "clicked" in)?
Old Aug 22, 2011 | 12:08 AM
Rick - PA's Avatar
Battery is charging now but it looks like i need a new one. quad has not run in more than 2 years, i tried again while the battery was charging and sounds like it want to start now but i checked the spark plug and still no spark. I will try to jump start in the morning, any idea why no spark? and thank you for helping!!!
Old Aug 22, 2011 | 12:19 AM
Electrical Expert
A battery that has sat around for two years without being on a maintenance charger is going to be toast for sure...
Is your quad cranking slowly? Perhaps that is the only problem. The CDI trigger voltage and the CDI power (if it is AC powered off the stator) are proportional to engine speed. Both of these are low when the engine is cranking slow. The trigger voltage is especially important because it has a threshold where it triggers the CDI to spark, or it doesn't depending on the trigger voltage level.
How many pins on your CDI? Is this two stroke or four stroke?
Get a meter ready and we can proceed from there once we know what CDI you have...
Old Aug 22, 2011 | 12:35 AM
Rick - PA's Avatar
Yes, it's cranking slow i guess because of the battery not having much power. Here is the picture of what the CDI looks like, it's 4 stroke. 6 pins, I will have to buy a meter.
Old Aug 22, 2011 | 08:30 PM
Rick - PA's Avatar
Got it working and runs great. Carb needed to be clean.
Old Aug 22, 2011 | 11:24 PM
Electrical Expert
I'm glad you got it working .
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
