RE
Old Jan 19, 2018 | 02:07 PM
  #21
MURDERED QUAD's Avatar
Default RE
I want to put a belt on by vairiator Fan but it won’t go on I’m trying to force it over the Vairiator fan
Old Jan 19, 2018 | 02:08 PM
  #22
scootergptx's Avatar
Supersock
Hired Gun!
Don't have any help on that, maybe start a new thread on it.
Sorry.
Old Jan 19, 2018 | 02:24 PM
  #23
Default RE
What do you mean start a new thread
Old Jan 19, 2018 | 02:34 PM
  #24
Supersock
Hired Gun!
Just like you started this one, but in your title, but a brief description of what you're looking for.
You'll get more people looking if they see a decent title, and keeping problems separate will keep them from being ignored as they may not be able to help with one problem, but might with another.
Old Jan 20, 2018 | 03:01 AM
  #25
Often, you have to take the outer half of the front pulley off. Undo the centre nut/bolt, pull off the plate, rollers and outer half of the pulley. Put the belt on, clean dust etc, from the rollers and tracks, assemble outer pulley rollers and cover plate as a unit, and slide onto shaft. Make sure the cover plate is on the splines when re-fitting the nut/bolt. Different makes use different designs, so the above is general advice.
