Timing chain
Old Jun 22, 2018 | 05:19 PM
Matthew Hinshaw's Avatar
Default Timing chain
I have a 110cc Chinese atv and the timing chain keeps slipping. I was hoping I could get some opinions on weather I should get a new chain or fix the one I have. I think the one I have is stretched and needs a link or two taking out. I don’t have a chain breaker put I do believe I could take a link out. Should I buy a new chain or fix the one I have?? Thanks!
Old Jun 23, 2018 | 04:30 AM
Fit a new chain, once all the automatic adjustment is used up, the chain is stretched beyond use, you are lucky a valve hasn't hit the piston if the timing has slipped. Are you sure you haven't lost the adjuster? On most 110s it looks a lot like the sump plug, thousands of owners have removed it when doing an oil change, and the timing chain tensioner spring and plunger shoot out instead of oil.
bwiencek
Nov 15, 2023 01:46 AM
Heartnurse73
Oct 5, 2019 12:23 PM
prmazdarx7
Sep 27, 2006 11:03 PM
98Lakota
Nov 10, 2000 07:27 PM
jeremy11
Aug 31, 2000 06:17 PM
