Rebuild 90cc or swap 110cc
Old Oct 3, 2018 | 11:36 AM
Frank Maloney's Avatar
Default Rebuild 90cc or swap 110cc
I have an extreme x 90cc atv. Motor is shot thinking of rebuilding the top end with a kit off e bay also kicked around the idea of swapping a 110cc 4 stroke instead. What's your opinion ?
Thanks
Old Oct 4, 2018 | 02:05 AM
The 90cc "Minarelli" engine has a good reputation. It was used by Polaris, and is still used by Apache and one or two others. The CVT is also well regarded, the feeble kick start leaves something to be desired, but (if fitted) is only supposed to be a "get you home" device. I suspect fitting a different engine would be quite difficult, and usually ends up with a machine that isn't as good as the one you started with. So my advice is do the top end rebuild.
Old Oct 4, 2018 | 03:18 PM
LT80's Avatar
LT80 Expert
IMO the cheapo china kits available for 30 bucks are junk.
Get a good oem piston or a wiesco and have your stock cylinder bored.
Old Oct 5, 2018 | 02:53 AM
Don't forget it is a "cheapo Chinese" engine Jack.
polarispredator7678
Feb 22, 2007 08:08 AM
Wes77
Jan 1, 2007 01:56 PM
happyface
Nov 13, 2006 09:59 PM
skiipsquadracer
Dec 14, 2005 09:43 PM
