bms stallion 600
Old Mar 9, 2024 | 10:16 AM
bob54's Avatar
Default bms stallion 600
has anyone found an aftermarket air filter for these things. If I order one from BMS it's $75.00 with shipping.
need something cheaper. Any ideas?
Old Mar 20, 2024 | 01:02 PM
bob54's Avatar
Still looking for an air filter to fit a customers BMS. Anyone find an after market that fits them?
Old Mar 22, 2024 | 04:01 AM
Depends on what you need, $75 for an element seems quite expensive but for an airbox would be cheap. If it is just an element, put a picture up with some dimensions. Also possible the aftermarket filter makers like Fram, will be listing filter elements for it in their catalogues.
Old Mar 22, 2024 | 06:47 AM
bob54's Avatar
Thanks, good idea
Old Feb 17, 2025 | 09:46 PM
Duckman84's Avatar
Default Bms stallion 600
I've done a bunch if research on mine. Look up a 2007 Yamaha rhino 700 air filter. Many of the parts in the BMS stallion are knock off rhino part. Front brakes calipers, air filter, rear differential. If you ever need to replace the master slave brake cylinder Amazon has them under Massimo UTV brake cylinders.
trailblazermudrunner
Apr 28, 2008 10:22 PM
BigRigIns
Mar 18, 2004 09:58 PM
lovemud
Jun 3, 2003 07:41 PM
wcrook1007
Mar 10, 2003 02:40 PM
BigBearFX
Jan 6, 2003 11:26 PM
