!#@#%ing seat
that happened to me a couple of times and i found that the wiring for my winch was holding up the seat from latching all the way. pull off the seat and make sure none of the wiring/relays are holding it up.
think i found the problem. looks like the middle catch is not engageing, somehow got bent up against the bottom of the seat. anyone know how to pull plastic back into shape without it breaking?
I took mine to the dealer with the same problem. I was pissed. I thought my seat was defective. He grabble the middle plastic catch and just pulled on it 'til it looked like it was back to normal. mine was prettey soft plastic, not brittle so I wasn't worried. That will do it. If your worried about breaking it , you could always use a heat gun.
Mine kept coming loose also ..... I lubed the latch shaft pivot points, and gave the latch spring one more wrap.
Has not come unlatched since [img]i/expressions/face-icon-small-smile.gif[/img]
No doubt reinstalling the P650 seat is an art within itself. I actually "bow" the seat in the center during installation and seems to be the trick to ensure the center "latch" engages correctly. I take one hand and press down hard in the center of the seat, while taking my other hand and sliding seat forward. Work "almost" everytime.
