!#@#%ing seat
Old May 19, 2003 | 04:59 PM
deck357's Avatar
Default !#@#%ing seat
anyone else have a problem with the seat on their 650? any time i shift my weight mine comes unlatched. really starting to p@ss my off having to stop every 10 min to relatch the seat.
Old May 19, 2003 | 05:21 PM
Lurch77's Avatar
You are the first person I have seen with that problem. Have you checked to make sure everything is tight, lined up correctly, and not bend or broke?
Old May 19, 2003 | 05:31 PM
deck357's Avatar
lurch, i've checked it out several times and nothing is bent or broken that i can see.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 19, 2003 | 05:38 PM
jwkawi's Avatar
that happened to me a couple of times and i found that the wiring for my winch was holding up the seat from latching all the way. pull off the seat and make sure none of the wiring/relays are holding it up.
Old May 19, 2003 | 06:46 PM
deck357's Avatar
think i found the problem. looks like the middle catch is not engageing, somehow got bent up against the bottom of the seat. anyone know how to pull plastic back into shape without it breaking?
Old May 19, 2003 | 07:00 PM
trailburner's Avatar
I took mine to the dealer with the same problem. I was pissed. I thought my seat was defective. He grabble the middle plastic catch and just pulled on it 'til it looked like it was back to normal. mine was prettey soft plastic, not brittle so I wasn't worried. That will do it. If your worried about breaking it , you could always use a heat gun.
Old May 19, 2003 | 07:24 PM
Vforcer's Avatar
Mine kept coming loose also ..... I lubed the latch shaft pivot points, and gave the latch spring one more wrap.
Has not come unlatched since [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 19, 2003 | 07:42 PM
SandBags's Avatar
I haven't seen a 650 yet where the middle seat latch catches. I would be looking at the wiring holding the seat up causing it not to latch all the way, as jwkawi mentioned.
Old May 19, 2003 | 07:47 PM
NovaKaw650's Avatar
Just bend that middle catch down lower. BTW - this has happened to just about everyone.
Old May 19, 2003 | 08:44 PM
Not2Old2ATV's Avatar
No doubt reinstalling the P650 seat is an art within itself. I actually "bow" the seat in the center during installation and seems to be the trick to ensure the center "latch" engages correctly. I take one hand and press down hard in the center of the seat, while taking my other hand and sliding seat forward. Work "almost" everytime.
