Lectron 46 anyone?
Old Jun 8, 2003 | 08:05 PM
MudStud's Avatar
Default Lectron 46 anyone?
I am thinking of the Lectron 46 for my stage II. I like the idea of not messing with the HSR bog ( I have teh HSR now) plus its someting different then the bandwagon....
Can anyone give any info on the carb? Will it be to much for a stage 2 stock bore? has anyone trail ridden with the lectrons?? I am not all that impressed with my HSR 42.. What do you think?
Old Jun 9, 2003 | 09:53 AM
DuneDevil's Avatar
I am also thinking about running this carb on my trail bike. I hope to see one this weekend. If I do get to see one, I will let you know what I think of it.
On the cable, I have just altered the stock cable to run on my lectrons. Also, you might have to alter your thumb throttle to get the full pull on the carb. It is no big deal if you have a die grinder or a dremal tool.
DuneDevil
Old Jun 9, 2003 | 09:56 AM
MudStud's Avatar
I run the twist.....
Old Jun 9, 2003 | 01:29 PM
predator530's Avatar
i am also thinking of running this carb on a honda atc 110 j/k but i am buying a 44 lectron and i need to know what throttle cable works for this carb
Old Jun 9, 2003 | 02:01 PM
MudStud's Avatar
Well,
I called fast by gast and they recomended the 44. They said the 46 and 48 are for Drag racers...
They also said the recently put the TM45 and L44 on a flow bench and the 44 flos more air then the 45! and it has higher air velocity!!!!
Plus, its not a bandwagon carb.. I decided to go with this carb [img]i/expressions/face-icon-small-smile.gif[/img]
Anyone want a used HSR42 with twist/cable/pump its for sale [img]i/expressions/face-icon-small-smile.gif[/img]
hush hush Dune Devil [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jun 9, 2003 | 08:51 PM
chop's Avatar
dude i also cursed my 45mm alot but its finally tuned in and this thing has no bog what so ever.also my carb settings are way of from what it was when it was shipped to me.the accelarater pump fixed my bog.
Hightower
Apr 27, 2004 09:19 PM
918sTaxi
Oct 30, 2002 11:41 AM
QUADLOCO
Sep 11, 2002 01:15 AM
Slobanshee
Feb 22, 2002 10:42 AM
the500bansheepilot
Feb 5, 2002 03:18 PM
