p650 problem
Old Jun 9, 2003 | 02:41 PM
kawip650's Avatar
Default p650 problem
my speedometer reads 0 all the time and quad will not switch into 4wd, everything else on the multimeter works fine and the engine seems to run fine. my thoughts are the speed sensor is bad. any suggestions?
also, is a special tool required to install the black spring, or can it be done without? i saw the procedure on nyroc's site, but i was hoping it could be done with a clamp or an extra set of hand. how much time is involved?
Old Jun 9, 2003 | 03:43 PM
DirtyWhiteBoy's Avatar
1) Take it in.
2) I've heard someone say they used an old rotor to push down on the spring. I can't imagine this went all that smooth and had to require 2 people. With the threaded rod, 2 nuts, 2 washers, and the end cap you can do it yourself without worry or much expense.
It'll take you longer the first time as you get familiar with everything. Once you get it down then it shouldn't take longer than 30 minutes, to do a shim job, with cleanup. Although, I never timed myself. I am usually doing 3 other things while working in the garage.
Old Jun 9, 2003 | 10:29 PM
Scotia650's Avatar
Welcome to the forum.
The speed sensor would be my first thought. Without input from the sensor the bike wouldn't engage 4wd. I damaged one early in my 650's life and had the same results, no 4wd and no readout on the speedo.
Old Jun 10, 2003 | 12:20 AM
ChaosInMt's Avatar
Its 5 bucks worth of parts for somthing you need every time you adjust your belt. I.E. you need it for regular maintance anyhow .
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
