bills or lrd for a blaster
alright fool thanx for the info but my friend has an fmf and i want to get something different on a chart the bills was way higher on hp but do i still have to change the jetting when i get a new pipe?
Just to let you know I don't use any of these pipes. I use a CT because it came with the 240 kit for free. However If I was going to use my hard earned money I would go with the FMF. Oh, I forgot your parents are probably buying it. Also dyno charts don't mean much if you can't read them. That Bill's pipe might make the most peak hp but where does it make it? I haven't seen the chart but I'm guessing it has a crappy bottom end a stockish midrange and screams on top, not a good power band for most riders. Usually the best power band to have is slightly better than stock bottom end excellent midrange and a little more on top.
If i were you i would go with the lrd pipe,it has
over all better performance than the other pipes,
plus it's adjustable so you can set the pipe to any setting you need.
Sep 10, 2015 01:56 AM
