bills or lrd for a blaster
Old May 10, 2000 | 11:34 PM
big_perm's Avatar
i got a 2000 blaster and it is pretty fast but i want faster. should i get an lrd or bills pipe? when u get a new pipe don't u have to redo ur jetting? if i do what kind of jetting should i use?
Old May 11, 2000 | 12:02 AM
Blaster668's Avatar
I would go with the LRD or an FMF. If you get the LRD make sure to order it chromed or it will rust in no time. To tell you the truth I think the best bang for the buck is the FMF.
Old May 11, 2000 | 12:09 AM
big_perm's Avatar
alright fool thanx for the info but my friend has an fmf and i want to get something different on a chart the bills was way higher on hp but do i still have to change the jetting when i get a new pipe?
Old May 11, 2000 | 05:29 AM
TopDawg's Avatar
Hey big_perm, Maybee you should not name call when someone is trying to help. how old are you?
Old May 11, 2000 | 01:24 PM
Blaster668's Avatar
Just to let you know I don't use any of these pipes. I use a CT because it came with the 240 kit for free. However If I was going to use my hard earned money I would go with the FMF. Oh, I forgot your parents are probably buying it. Also dyno charts don't mean much if you can't read them. That Bill's pipe might make the most peak hp but where does it make it? I haven't seen the chart but I'm guessing it has a crappy bottom end a stockish midrange and screams on top, not a good power band for most riders. Usually the best power band to have is slightly better than stock bottom end excellent midrange and a little more on top.
Old May 11, 2000 | 10:27 PM
big_perm's Avatar
thanx again ang i wasn't name callin. u know it's slang like instead of sayin dude or anything i am 14 by the way.
Old May 13, 2000 | 11:43 AM
suzukiboom's Avatar
If i were you i would go with the lrd pipe,it has
over all better performance than the other pipes,
plus it's adjustable so you can set the pipe to any setting you need.
Old May 15, 2000 | 07:08 PM
99fasterblasters's Avatar
Big-perm, (waz-up) I got the CT pipe and the Fmf, I like the FMF better, everybody has them for a reason, buy one and see for yourself, rock-on homey!!!!
Old May 18, 2000 | 07:28 PM
fmfblaster's Avatar
if those are your only choices i would go with the lrd i have a fmf and it works great
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Sep 10, 2015 01:56 AM
1966F100
Aug 21, 2015 07:10 PM
