Help needed replacing rear bearings on a Raptor
I've tried driving out the bearings but no go. I chipped a peice of the carrier trying to do so... has anyone removed them out? Is there a special tool? I got everything to get theis Raptor going.. just need to install it
Take a long screw driver. From the inside of the carrier tap on the very small edge of the bearing on the opposite end of the carrier. Rotate the spacer little by little so you can see the available edge of the bearing and tap on all edges of the bearing equaly and work the bearing out. Once one is out the other is much easier to get out. The bearings rest on a seat you cannot hit on one to drive out the other. This worked for me, maybe it will for you.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
hoopduerr
Jun 2, 2015 09:01 AM
