winch test
Old Jun 22, 2003 | 02:50 PM
liquidplumber's Avatar
Default winch test
is there a simple way to test a winch? it is off the quad can i just use a battery and some cables?
it is a warn and the two connections just say #1 and #2
thank you
Old Jun 22, 2003 | 03:14 PM
Coyotechaser's Avatar
Default winch test
Is there a switch?
Old Jun 22, 2003 | 03:48 PM
Default winch test
I have the switch I have the solenoid I dont have the quad I am trying to troubleshoot
this on the bench any suggestions?
Old Jun 22, 2003 | 04:29 PM
Default winch test
My winch has 4 wires. Two wires go to the switch from the winch and two go to the switch from the battery. I know the Warn is different.
I don't see why you couldn't just wire it to the battery also using the switch. The winch will drain the battery without anything to charge it.
My winch works directly off of the battery. The only thing the quad does is hold the winch and charge the battery.
I don't know if the battery could be too powerful for the winch. (If your using a car battery.)
Old Jun 22, 2003 | 04:51 PM
Default winch test
Coyote thanks for the reply but they do sound different. My switch is a low voltage looking thing
that runs to the solenoid.There must be an easy way to jump things out to test I just cant see it.
thanks again
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
Aug 15, 2019 03:13 PM
kbazzy
Sep 26, 2015 11:26 AM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
