honda trail 70 need help!!
Old May 14, 2000 | 06:08 PM
kx80's Avatar
my brothrer was riding my trail 70 in the woods the other day and was in second and down shifted to first he said it reved real high and then killed on him he brought it home and now it has no comp. and makes a tinky tinky sound when u kick it over. ps he said it made a pop then stopped running. can any one pls help and give some advice on what might be wrong and what to look for? thanks
Old May 14, 2000 | 06:26 PM
Y2K300EX's Avatar
It sounds like what happened to my friends quadsport. He broke the rod, but for you it might just be that he blew out a gasket somewhere in the topend of the motor. Is it leaking oil anywhere?
Old May 15, 2000 | 06:41 AM
snowshark's Avatar
It sounds like its time for a engine rebuild. Do you have any compression, problaly not. The piston isn't moving.
I hope you or some friends are mechanically inclinded.
Old May 15, 2000 | 04:41 PM
kx80's Avatar
no its not leaking oil just no comp and it makes the sound and yes i am mechanically inclined lol
Old May 15, 2000 | 04:45 PM
snowshark's Avatar
Great that your mechanically inclined,
Get a Clymers or Honda Service manual & get into the engine. I used Clymer to rebuild my kids Z-50R.
Good Luck
Old May 16, 2000 | 01:11 AM
2000400EXinLA's Avatar
sounds like it ran low on oil.
Old May 16, 2000 | 04:52 PM
kx80's Avatar
its got plenty of oil i had just changed it about 3 weeks before this happened
Old May 16, 2000 | 11:40 PM
Stroke9's Avatar
I think the transmission was shifted between gears and then wide-open throttle applied with no crank shaft load, resulting in extreme high RPM. The engine was a little worn and so a maybe kinda loose. Something was overstressed and broke. Maybe a piston crown, maybe the rod ... Time for a tear down.
Nondem
Feb 22, 2020 12:20 PM
RickyMac
Mar 5, 2016 07:27 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
