throttle adjustment
Old Jul 6, 2003 | 07:17 PM
abcdefg's Avatar
Default throttle adjustment
I'm hoping someone can help me out with the correct adjustment of the throttle cable. Is there a specific way. I've got a 500ho and it was running poorly. I adjusted the throttle cable (adj. along handlebar) so it would engage the clutch and then backed it off a hair. Runs great , except when I go in reverse, it will kill the engine when I give it throttle. HELP.
Old Jul 7, 2003 | 12:28 AM
samclow's Avatar
I think you are talking about adjusting the E.T.C switch to get the freeplay out of the thumb throttle,and this will also help if you have a back firing problem.You will need to re-set the idle speed with the idle screw under the carb after making these adjustments.
Old Jul 9, 2003 | 06:43 PM
cid87's Avatar
help 03 sp500camo 100miles idolspeed1200+-100 will not stay aways drops to800 area .tried idol screw & at cable by thordle lever still drops &sometimes stalls alway adjusting rpm drops at idol machine in neut. help help
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
dougn85
Aug 5, 2015 07:20 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
Jul 30, 2015 09:21 AM
