SP 500 belt slips
Old Jul 10, 2003 | 10:11 PM
hotdog's Avatar
Default SP 500 belt slips
I have been riding with a friend who has a four year old KAW 400 ..I have a 2002 SP 500...and in our trips he never shifts down into low...but i have to..when the trail gets real rough and i am going slow..I give it the gas but it's doesn't move..so the belt must be slipping ..I doesn't burn or smoke...I shift to low and no problem...maybe i should have the belt adjusted ?? I just can understand why the KAW never needs to be shifted he's going through the same stuff i am ???[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 11, 2003 | 01:51 AM
PRAIRIETWIN's Avatar
I've owned both.
The 400 Kawie is very low geared. It would only run 47mph on GPS.
The 500 SP would run 64mph.
Put a blue with green stripe spring in front clutch. Also check belt and adjust!
This will give you more low end power. Then put a stiffer rear clutch spring in(all blue?)
This will keep the 500 in low gear longer before upshift.
Old Jul 11, 2003 | 09:52 AM
hotdog's Avatar
thanks for the tip ..Unfortunatly I don't know much about the mech. of the bike ..but will look into to it...
Old Jul 11, 2003 | 11:53 AM
Wolfhound's Avatar
heelclicker.com
Old Jul 11, 2003 | 01:08 PM
lovemud's Avatar
A belt can get "glazed" also right? I'll bet you'll need a new one when you make your modifications.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
