Front sprocket
Old Jul 17, 2003 | 02:10 PM
haulin's Avatar
Default Front sprocket
I know it's been beaten to death, but could someone tell me what front sprocket to buy for my pred. 13 tooth. Thanks in advance.
Old Jul 17, 2003 | 03:04 PM
Predator03's Avatar
If you want to gear it down to make it more rideable in the woods, a 13 tooth is the way to go. I went ahead and put a 39 tooth on the rear of mine. Unless you have long straight runs, where top end is what you need, I'd recommend that gearing. You could try just putting on the 13 and see if that is what you like. It will rev quicker and you'll pick up more on the low end. I needed to go lower on mine, because of where we ride. Lot's of rocks to climb, and steep hills, the stock gearing was useless there.
I would also recommend going to Sidewinder website and buying at least the hi tool steel sprockets. They are a little more expensive, but will last longer than the aluminum.
Hope that helps
Scott
Old Jul 17, 2003 | 04:18 PM
haulin's Avatar
Thanks Scott. Does Sidewinder have the 13 tooth sprockets? I have read around here and other places that you have to use the one off of a honda xr650l or something.
Old Jul 17, 2003 | 04:20 PM
pudljumpr's Avatar
Give Sprocket Specialists a call. They have a 13T for the pred. it is off one of the 650 Honda bikes, but they put up a new listing for the predator. It's $20 for the 13T.
Old Jul 17, 2003 | 04:23 PM
haulin's Avatar
Cool. Thanks. I appreciate it.
Old Jul 17, 2003 | 05:27 PM
Predator03's Avatar
Yes, they have the 13 tooth. It's the one I bought for mine. It's forty bucks and worth every penny.
Scott
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
