Tired of Loosing Your Black Fender Plastic?
Old Jul 22, 2003 | 12:07 PM
tuffEnuf's Avatar
Default Tired of Loosing Your Black Fender Plastic?
A simple solution for those that like to blaze trails through the brush. You will need a 24" sections of 1/2 inch angle dexion (used frequently to mount garage door motors. For each joint you will need two 1" button head phillips head screws, (same size but longer than other screws in your plastic), 2 self locking nuts, and 4 one inch flat washers sized for screw, a drill, wrench and screw driver. Cut off dexion into 3-holed sections so that three holes are left exposed. Hammer dexion flat on a hard surface. Center dexion on underside or top side of fender plastic but over the joint seam of black fender plastic so there is one inch on either side of seam and drill through plastic in each end of the dexion. Place flat washer on each side of screw, install nut & Tighten.
Do all joint seams. Spray paint button head washers black or leave as is. Haven't lost anymore black fender plastic. [img]i/expressions/face-icon-small-shocked.gif[/img]
02 Prarrie, Super Trapp IDSX complete exhaust, K&N Filter & Needles, Modded airbox, 142/145M, Penland Race CAMS, EPI Black & Red Springs, DG Snorkle & Holeshot Module, 25 X 12 X 8 ATRs & 25 X 12 X 13 Mudmachines--wheelie prone; scary fast + some.
Old Jul 22, 2003 | 12:18 PM
Raczzer's Avatar
Thanks for the good idea. Sharing good tips and mods like this is what it's all about!
Old Jul 22, 2003 | 12:24 PM
badprairie's Avatar
pics?
Old Jul 23, 2003 | 12:47 PM
tuffEnuf's Avatar
Will take some pictures and get back with you.[img]i/expressions/face-icon-small-happy.gif[/img]
Schneider
Jul 24, 2015 05:05 PM
1966F100
Jul 24, 2015 02:17 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
