02 Scramble 400 tuning help
I purchased a HSP performance kit (Gen-II pipe, hypershift clutch kit and K&N filter). I had a dealer install it, but he is a complete moron (should have bought the rcr). I ride in central IL, 80-100 degrees, if anyone else is ridding in the same region, what Main jet, clip position and airscrew setting are you using?
Thanks for your help in advance.[img]i/expressions/face-icon-small-confused.gif[/img]
Nope, the dealer did not offer that valuable piece of paper work, nor did he give me the jets that were supposed to have come with the kit. A week after the install I had to pull the secondary clutch out and replace the buttons.
UMMM grease the clutch weights? IDIOT!!! I would find out what main is in your quad now and find out what mains hsp sent. If you dont have the ones from hsp then I think the dealer owes you some main jets along with the instructions. I used to live in Joliet ILL. With the hsp pipe, clutch kit, and K&N filter your main should be between 145-150 with needle set on middle to second slot from top, airscrew 1 1/2 turns out. It will change with weather but this is close. OH wait is this for a 250 or a 400?
When all is said and done, it might not be a bad idea to notify Hot Seat which dealer that is, and what they did....er, I mean didn't do. Sounds like 2many has you covered. [img]i/expressions/face-icon-small-happy.gif[/img]
If in doubt, give the nice folks at Hot Seat a call. They should be able to send you a new set of instructions or help you out over the phone[img]i/expressions/face-icon-small-smile.gif[/img]
Elkaholic
Sep 6, 2015 02:44 PM
