New 700 Prairie smoking and only 1 mile on it.
Old Aug 9, 2003 | 11:38 PM
TheForce's Avatar
Default New 700 Prairie smoking and only 1 mile on it.
I hardly had it off the trailor and it was really smoking. What does that mean and what is the cure?
Old Aug 10, 2003 | 12:08 AM
Jeffro31's Avatar
I would run it a couple of hours , could have some oil in the top end from when it was built , or maybe the ring gaps are alligned .
Old Aug 10, 2003 | 12:14 AM
orangerocket926's Avatar
its because of the over flow going right into the airbox and if u have too much oil in it it will get into ur airbox and then sucked into ur carbs thus making it smoke really bad.
Old Aug 10, 2003 | 12:18 AM
TheForce's Avatar
I hope it goes away. I checked the oil level and it seemed a little high so I took a few oz. out. I figured I would have some oil in my airbox so I popped the top and to my surprise, it was dry as a bone in there. I guess it would have had to be pretty full to get blown out going under 10 mph.
Old Aug 10, 2003 | 12:30 AM
mine did after i changed the oil and now it dont smoke at all
Old Aug 10, 2003 | 01:44 PM
TheForce's Avatar
Well now that it is light outside I figured out where the smoke was coming from. It is the oil and residue burning off of the outside of the muffler. I can't believe it smoked as much as it did. I was sure it was burning oil. Thanks for all your help!
Old Aug 10, 2003 | 01:59 PM
Ross650's Avatar
TextHowdy,
just be sure that the oil isnt overfilled. Check the level with the stick screwed all the way in. If it has a thimble full too much it will suck it into the airbox. Have a goodun!!!!!!!!!!
Old Aug 10, 2003 | 02:13 PM
DirtyWhiteBoy's Avatar
Yup, you figured it out. Mine smoked quite a bit also. You can also tell because the manufacturing oil has a unique smell to it.
JR50
Aug 27, 2015 07:08 AM
velcro7279
Aug 24, 2015 01:15 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
