heat shield melt??
Old Aug 18, 2003 | 09:34 PM
MadKaw1100's Avatar
Default heat shield melt??
During a trail ride I smelt something burning on my 1996 Sportsman 400 4x4. Once I stopped I notice smoke coming from underneath the black plastic exhaust shield on the right leg side. I also noticed a loss of power at high rpms. The fan never kicked on, nor the high temp light. Once I got home, I pulled the plastic panel and found the insulation had scorched under the aluminum tape.
Has the insulation just given up the ghost after 7 years? Do I have a heat problem? And how do I fix it?
If it makes a difference, the atv is completely stock. I’m the original purchaser and no mods nor any recent adjustments to anything.
Also where can I get some more of that metal lined insulation?
Old Aug 18, 2003 | 10:03 PM
ftwflh's Avatar
I had this happen to my 425.You can get the tape insulation at a good auto parts.
Old Aug 18, 2003 | 10:17 PM
MadKaw1100's Avatar
What caused your insulation tape to melt/burn?
Old Aug 18, 2003 | 10:20 PM
ftwflh's Avatar
Mine just feel out from use and abuse
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
