yfz450 problem maybe???
Old Aug 22, 2003 | 04:03 PM
RapBryan's Avatar
Default yfz450 problem maybe???
I might be having a problem down shifting. When shifting down from 4th sometimes the shifter sticks and won't move until you mess with it. It kinda sucks when you can't down shift. It doesn't happen all the time, but when it does I'm usually coming into a tight corner and need to drop down into 2nd. Anyone else having this problem?
Bryan
Old Aug 22, 2003 | 05:44 PM
bansheeguru's Avatar
I have not had this problem happen, so far everything has been very good.
Old Aug 22, 2003 | 05:47 PM
selector's Avatar
Make sure you're far enough off the gas - if you're a "no clutch" guy like me.
selector
Old Aug 28, 2003 | 10:50 AM
RapBryan's Avatar
I figured out when it is doing it. It is when I'm in 4 or 5th, pull in the clutch and gear down, the shifter sticks in 4th every time. If I let the clutch out some times the shifter pops back up. If I don't use the clutch it works fine. Are any of you with 450's having this problem. If you would next time you ride try to duplicate it for me and let me know if your does it. I might have to take it back to the dealer.
Thanks for the help,
bryan
Old Aug 28, 2003 | 11:25 AM
Dill's Avatar
there is a problem with the shift drums having a burr on them on a few of the new YFZ's...take it to your dealer and tell them to look up the service bulletins on the 450, and this will be one of them..they will fix it under warranty.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
