Rear Cv Joint Question
Last Night I was Having A hard time removing the rear axle from the transmission So I took A break. When I got home my father yanked it out and it came apart where the rear joint is on it. All the ***** fell out and everything Is this possible to fix or not
this is a very easy fix just have to be careful because it it time comsuming they will go back together it just takes allot of time they will go back together just have to make sure you align the ***** in the cage up. i just did mine a month ago from a torn boot. Make sure you clean it very good before you put it back together and use the same kind of grease from polaris . todd
