Rear Cv Joint Question
Old Aug 23, 2003 | 02:37 PM
BuckinHO's Avatar
Default Rear Cv Joint Question
Last Night I was Having A hard time removing the rear axle from the transmission So I took A break. When I got home my father yanked it out and it came apart where the rear joint is on it. All the ***** fell out and everything Is this possible to fix or not
Old Aug 23, 2003 | 04:26 PM
hotrodtodd's Avatar
this is a very easy fix just have to be careful because it it time comsuming they will go back together it just takes allot of time they will go back together just have to make sure you align the ***** in the cage up. i just did mine a month ago from a torn boot. Make sure you clean it very good before you put it back together and use the same kind of grease from polaris . todd
Old Aug 23, 2003 | 09:56 PM
BuckinHO's Avatar
Yeah I just Got It together I stuck the ***** and cage in the freezer And Popped it in worked great Thanks
STLyamwar
Jul 25, 2020 04:44 AM
metal249
Jul 28, 2015 09:35 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
tporath
Jul 11, 2015 12:31 PM
