warrior clutch
anyone ever changed the clutch on a warrior. I am triying to get to the oil pump and apparently I have to take the clutch off. The book says I need a special tool to hold the clutch boss? while I loosen a nut. Problem is I can not find a nut to loosen. There is a piece with 4 or 5 phillips screws that appears to get pushed in when you engage the clutch.
Any help would be greatly appreciated.
thanks
-ypman
thanks
-ypman
ok I figured out where the nut is located. Next question, does any one think it is a bad idea to remove the nut holding the clutch on with an impact wrench seeing as I am not sure how to keep the clutch basket from moving?
Thanks
-ypman
Thanks
-ypman
