warrior clutch
Old Sep 9, 2003 | 11:16 PM
ypman's Avatar
Default warrior clutch
anyone ever changed the clutch on a warrior. I am triying to get to the oil pump and apparently I have to take the clutch off. The book says I need a special tool to hold the clutch boss? while I loosen a nut. Problem is I can not find a nut to loosen. There is a piece with 4 or 5 phillips screws that appears to get pushed in when you engage the clutch.
Any help would be greatly appreciated.
thanks
-ypman
Old Sep 9, 2003 | 11:46 PM
ypman's Avatar
ok I figured out where the nut is located. Next question, does any one think it is a bad idea to remove the nut holding the clutch on with an impact wrench seeing as I am not sure how to keep the clutch basket from moving?
Thanks
-ypman
Old Sep 10, 2003 | 12:09 AM
Ball's Avatar
The impact is the only way to get it off.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
