Warrior carb problem
Old Sep 10, 2003 | 01:31 PM
Hondanutcase's Avatar
Default Warrior carb problem
A buddy of mine has a yamaha warror, as we were riding last weekend the overflow tube on the carb was leaking bad. At first we thought no big deal until we noticed it would not stop. Ended up draining the whole tank. Any suggestions to the problem?
Old Sep 10, 2003 | 02:39 PM
Crotts's Avatar
Check the floats in the carb, sounds like there stuck.
Old Sep 10, 2003 | 03:19 PM
JakalWarrior's Avatar
hit the carb with something [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 10, 2003 | 03:25 PM
Is this something that you have done?
Old Sep 10, 2003 | 04:03 PM
yes, easiest way to unstick the float (usually) is to hit the carb. I dont mean hard, just to free up the lil thing float inside. I usually smack it with the plastic end of a screwdriver.
Old Sep 11, 2003 | 05:17 PM
Thanks, I will pass on the info
Old Sep 11, 2003 | 05:28 PM
Ball's Avatar
Turn off your gas petcock on the tank first. Then drain the float bowl w/ the little screw on the bottom of the carb. Otherwise you can probably tap on the carb all day and will not free the floats. Your gas is coming from the overflow because the floats are not closind off the gas when the bowl fills up. If you don't drain your bowl the floats have a tiny bit of tension on them and likely will not free themselves. I flipped my Warrior a few weeks ago and had this problem. took a few minutes to figuire why they wouldn't become unstuck. Eventually got it. Hope this helps ya!
Old Sep 11, 2003 | 05:30 PM
Ball's Avatar
P.S. Just tap it with the plastic end of a screwdriver like JackalWarrior said. It doesn't take much so don't wail on it.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
