JUst installed holeshot module on p650
Old Sep 24, 2003 | 09:50 PM
sicnj's Avatar
Default JUst installed holeshot module on p650
i just intalled the holeshot, i only had a chance for a quick ride on the street. Didn't really feel the diffrence, i figuired i could weelie without yanking on it. could i have gotten a bad mod? Please give me your thoughts
Old Sep 24, 2003 | 10:00 PM
MikeyBoyesq's Avatar
First, check to make sure you hooked it up correctly. Its easy to get confused and accidentally hook up the holeshot module to the pink wire incorrectly. Remember its supposed to hook up to the pink wire that goes INTO the cdi and not the other pink wire that goes down to the speed sensor.
Second, if its correctly installed, you should only notice a difference when you are moving at 3mph or less and then hit WOT. It won't kick in if you don't hit WOT!! Also, you should notice more of a difference if you do it from a dead stop.
If these two steps don't show any improvement at all (and you are sure you are on hard pavement with good traction when testing it), I recommend that you call Don at DG. He is very helpful and easy to talk to.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 24, 2003 | 10:29 PM
sicnj's Avatar
what is WOT?
Old Sep 24, 2003 | 10:38 PM
z400rider28's Avatar
Wide Open Throttle
Old Sep 24, 2003 | 10:43 PM
sicnj's Avatar
thanks
Old Sep 26, 2003 | 08:56 AM
prairie633's Avatar
sicnj, check your connectors. Mine didn't work at first because the blade thing in the connector didn't bite through the insulation like it was supposed to. After I fixed that , I have never had any more problems.
Old Sep 26, 2003 | 09:33 AM
sicnj's Avatar
yeah that was my problem i lost 10 mph. so i checked the connections. Bam that holeshot module is bad .
Old Sep 26, 2003 | 01:20 PM
TriumphDude's Avatar
I would recommend not using those cheap connectors and soldering the wires and using heat shrink tubing (double it up so it it is water proof.). I didn't want to cut my wires anymore than needed, so I
ran the ground to the battery . No reason to cut a wire for the negative.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
