blaster shifting problem!!!
Old Sep 26, 2003 | 04:42 PM
soon2bBlaster's Avatar
Default blaster shifting problem!!!
my 04 Blaster wont shift up from gears 3 to 4 and 5 to 6 good. the lever will go up but it wont shift unless i get the rpm's up high but i dont like doing that and i shouldnt have to could it be tranny oil or do i need to go down a size in my jet because i just put in Boyesen reeds and run with no lid please help
Old Sep 26, 2003 | 05:55 PM
duckdiaz's Avatar
If its 04 blaster it may still b under warranty, take it to the dealer let them look at it…If something’s wrong they will have to fix for free...
Old Sep 26, 2003 | 08:34 PM
fivel250rman's Avatar
If its not under warranty and you want help to fix it,tell me does the clutch have some freeplay in it?For example :can you pull the lever in a little before it gets hard to pull or is it tight?
When you say it doesn't shift good, is it hard to pull up on the shifter and does it pop out of gear sometimes?answer those questions and I'll help.
Old Jun 18, 2006 | 05:05 PM
BDOW890's Avatar
Did you ever figure out whats was wrong???
I AM HAVING A SIMILAR PROBLEM
when i am shifting up every now and then the shifter gets stuck up, so in order to shift up again to another gear i have to push the shifter back down and then pull it back up... and also when i am down shifting i have trouble shifting from third to second and second to first unless i am moving at a decent speed... I Tried changing the trans fluid about a week or so ago and it did get alot better what else could i do to fix this??? Thanks Alot!!
Frisky2050
Apr 9, 2020 11:19 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
joeyupton
Jul 14, 2015 11:51 AM
sara durrant
Jul 6, 2015 05:32 PM
