Are any of the pull behind Mowers any good?Thinking of a p700 instead of tractor.
Old Oct 1, 2003 | 09:37 PM
Cavaselis's Avatar
Default Are any of the pull behind Mowers any good?Thinking of a p700 instead of tractor.
If i get a tractor its gonna be a diesel kubota ~9-10k with plow.I can do a prairie 700 with plow and pull behing mower for~7500-8500.Do they work good?If so who makes a good one.
Thanks
Old Oct 1, 2003 | 11:25 PM
biggin's Avatar
Plowing will always be a tractors job IMO. But as far as using a pull behind mower, yes they work good. My friends is a 44 in 8hp. I do not know the exact brand. You do not NEED a 700cc atv to pull a mower or plow. I have plowed and cut grass with my 230 Quadrunner. Plowing is just a tad to much abuse IMO. It pulls it fine in low range, just more abuse than I am willing to subject my atv to. But I 'm sure the 700 is more fun to ride.
Old Oct 2, 2003 | 12:26 AM
Raptoryfn660r's Avatar
RIP Dear Friend
I don't think the p700 was every designed with competing against the work horse diesel kubota.
If you like the p700 check out Swisher's web site
I use a Swisher 50 inch bush hog pulled by a honda 300 4x4 and it works great but they don't make this model anymore.
Chet
Old Oct 7, 2003 | 11:24 PM
vampirerider's Avatar
Swisher makes good stuff. I have what is considered a finishing mower but they have trail blazers as well. They are well designed and tough.
Old Oct 8, 2003 | 02:50 AM
JohnO's Avatar
I have a 44" swisher I haul behind my Cat 500 from time to time. It's handy, but no substitute for a real mower, especially if you have a lot to mow. Your thumb gets tired trying to hold a constant (and slow) speed, and quads don't turn nearly as tight as a small tractor or lawnmower. I've used the swisher to cut a few acres, but only when my regular lawnmower is broken down.
For the $9-10k you mentioned, that's enough to get a used JD 750 diesel mini tractor and mower, and have enough left over to get a 400cc utility quad. Best of both worlds.
txkevin
Sep 21, 2015 02:02 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
