650 Problem?
Old Oct 10, 2003 | 12:35 AM
login's Avatar
Default 650 Problem?
I have just got my new AC 650 and only rode it about 3 hours on the first day. When I went to start it today the water temp light was flashing on/off before I even started it. I changed the fuse in the fan and no change. I checked the electrical connections and could not find any loose. I decided to let it run for a little and after about 2-3 minutes the light quite flashing. I rode it a little and the fan on the radiator worked as it should. My question is do I have a problem?
Thanks
RD
Old Oct 10, 2003 | 01:28 AM
DaveB's Avatar
Um.....since you are probably one of maybe 9 guys on the continent that have so far put any time on a AC 650, I would think this question best asked of your dealer. Maybe this is a self-diagnostic test....dunno. Use your warrantee.
Old Oct 10, 2003 | 03:37 PM
BushWacked's Avatar
Did you NOT get a users manual with your purchase???? If not call the dealer, they should have an answer for you, don't expect everyone here to know how to diagnose your machine for you, even though I'm sure many answers would come about, they would likely be incorrect assumptions. Call your dealer.
Old Oct 11, 2003 | 10:14 AM
SHOTGUN's Avatar
call your dealer first, where it is a kawasaki 650 motor, go to NYroc website, it has a collection of information about 650's.
Most of the time the answer is there, of post on the Kaw forum.
Nyroc
Old Oct 11, 2003 | 10:23 AM
DanW's Avatar
If it quit doing it, it might have just been a fluke thing due to the newness of the machine. Maybe the sensor had to set itself.
Old Oct 11, 2003 | 11:14 AM
GUTTJR's Avatar
WE JUST HAD A 650 LE IN THE SHOP AND IT DID THE SAME THING, ONLY THE PROBLEM WAS THE FAN MOTOR WAS TURNING BUT THE FAN BLADES WERE NOT, THE COMPANY THAT MANUFACTURED THE FAN FORGOT TO BUT A ROLL PIN IN THE FAN MOTOR THAT TURNS THE FAN.
Old Nov 2, 2003 | 10:57 AM
Catboy400i's Avatar
does the light go off after it is started? if it does then dont worry about it. My grandfather has a 375 auto and it does the same thing, but after you crank it, it will go off and function properly
Old Nov 2, 2003 | 03:08 PM
Wires's Avatar
That's funny..... The cat manual isn't worth the paper it was printed on. If I wanted to read 100 pages of "How not to ride my bike" then I'd buy a book...... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 2, 2003 | 05:15 PM
bfb750BF's Avatar
Did you check your coolant level?
Some dealers do a poor job on set-up & sometimes overlook things like correct tire pressure, engine oil level & coolant. Before I take delivery of anything, I always gave it a road test & a good look over but now I check everything to be sure everything works correctly & check all of the fuilds.
The Owners Manual does not include trouble shooting sections, the "Service Repair Manual" would be the Manual to get.
Old Nov 3, 2003 | 04:42 PM
ttaylor's Avatar
Since the 650 is the Kawasaki motor. You can check that forum for a lot on the helps with motor and electrical. It seems I remember reading about a problem with the 650 and the warning lights.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
