whats more likely the problem
Old Oct 11, 2003 | 02:55 PM
shoemaro's Avatar
Default whats more likely the problem
My 95 scrambler is getting water in the crank causing it to blow steam out of the exhaust and hardly run. I put a new cylinder, and head, with new gaskets on it. Still did it. I talked to a mechanic and he said that it is the water pump seal or a my counter balancer is bad. What is more likely to be the problem. Right now the engine is locked up because I think the water locked up the crank.
Old Oct 11, 2003 | 03:01 PM
CED's Avatar
CED
Pull your plug and see if you can spin the engine over.Pull your counterbalancer dipstick and see if you have any water in it.
Old Oct 11, 2003 | 03:13 PM
shoemaro's Avatar
pulled my head off and i couldn't move the piston, used the shaft of a wooden hammer to try to beat it down and it didn't move. I checked my counterbalancer oil and there really wasn't anything in it, no oil or water it looked a little moist possibly water had been in it.
Old Oct 11, 2003 | 03:38 PM
CED's Avatar
CED
I think your counterbalancer is locked up,due to no oil and probably water getting in there.Your balancer is ru off of a gear that is driven off the crank ,and if it's locked up the crank will not turn.So many people neglect checking the counterbalancer oil,and this is a cause for more rebuilds than just about anything else.I'm not saying you didn't check yours ,just trying to help someone else from having this happen to them.By checking it often you will notice very quickly when the seal will go out and this will save you a lot of money.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
