Idea for front diff lock?
Old Oct 14, 2003 | 10:17 PM
mountainclimber's Avatar
Default Idea?
You know how the rear ends of our quads are locked. Well what if you bought a rear axel assembly and put it up front? Would it work? Is it a good idea or no?
Old Oct 14, 2003 | 11:05 PM
cpalm1's Avatar
Default Idea for front diff lock?
it would be almost impossible to turn
Old Oct 15, 2003 | 02:51 AM
DaveB's Avatar
I believe this has been done already......order the center section out of the rear diff, and install it in the front. Lots of guys have run DirtyHowies lockers in the front as well.....same thing, no differentiation. Makes steering heavy at slow speeds.
Old Oct 15, 2003 | 10:34 AM
Olddirtybastard's Avatar
It will work, I have done it. Just keep your old diff because you will get tired if the hard steering.
Old Oct 15, 2003 | 11:32 AM
ZukiRacr250's Avatar
How did you get the King Quad diff to work in the Cat? I was also looking into doing that modification but i noticed the King Quad diff had a ratio of 3.09:1 and i think the Cat has a ratio of 3.6:1 ? Could you explain to me how you over come this difference? Or do you ?
Old Oct 15, 2003 | 11:46 AM
If your Cat is an Auto, it has the 3.09s. If it is a manual you have to set up your rear diff with the gears from an auto.
txkevin
Sep 21, 2015 02:02 PM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
Biggieshortie89
May 26, 2015 08:01 AM
