Clutch adj on 400 Bayou 4x4
Old Oct 15, 2003 | 01:43 PM
tprender's Avatar
Default Clutch adj on 400 Bayou 4x4
About a month ago I came across a '94 400 Bayou 4x4 and I need to adjust the clutch on this. On the right side case I have taken the black plastic cover plate off and there are 2 bolts under it. The one on the right I have loosen the nut and turned the screw to the right to I get pressure and then back 1/4 turn and tighten the nut. But, I tried this with the other bolt on the left but it doesn't work the same. What do I do and did I do the bolt on the right correct? Thanks for the help in avance. Tried a search but came up empty.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
rcappie4
Sep 9, 2015 07:04 PM
