hub fluid replacement???
Old Oct 20, 2003 | 10:10 AM
polarisbear500's Avatar
Default hub fluid replacement???
can someone please tell me the steps for changing the hub fluid on a 99 sportsman 500. i got the mobiler 1 syn. ATF already. thanks.
Old Oct 20, 2003 | 10:18 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
well
if its like a Scrambler,,,,you pull the drain plug on the hub and drain. then rotate the holes up and fill to the 4:00 position.
Old Oct 20, 2003 | 11:08 AM
this may sound kind of dumb, put i am just now learning how to work on my 4-wheeler. so, the to get to the hub, do i need to take the wheel off and then the hub and drain is there? then put the drain hole at the 4 position like a clock? any detailed help would be nice. thanks again
Old Oct 20, 2003 | 02:23 PM
BigBadScrambler's Avatar
You dont have to take the wheel off. It may make it easier to put a drain pan under there though if you doo. But, there is a plug with a hex head that is on the side of the hub. It should be lie a silver color. That is the drain/fill plug. Remove that and let the fliud drain out. There won't be much in there. Then, rotate the wheel/hub so that the drain plug is at a 4:00 position. I like to use a small seringe to squirt the new fluid into the hub. It makes things a lot easier. (You can get the seringes from Tractor Supply). Fill the hub until the fluid starts to leak out. Then put the plug back in. Its as simple as that
Old Oct 20, 2003 | 02:42 PM
Bing's Avatar
Super Quad Patrol
what bigbad said
you can also fill the wholes when they are upright, and then turn the the 4:00 position to drain the excess (a little messier)
clean and replace the plug
Old Oct 20, 2003 | 03:16 PM
thanks for all the help. it sounds easier now, thanks again!!!
Old Oct 20, 2003 | 07:53 PM
highwayman's Avatar
I change hub fluid 3 or 4 times a year, spring and fall and a couple times in the summer, it is real easy if you follow the above steps. I fill it at 12 o'clock and dreain at 4 o'clock it doesn't take to much.
robert301972robert
Aug 30, 2015 11:34 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
toonces
Jul 28, 2015 01:58 PM
NatePerz
Jul 27, 2015 03:27 AM
rcappie4
Jul 10, 2015 04:54 PM
