Anyone know how to adjust the amount of engine braking?
Old Oct 21, 2003 | 01:51 PM
csdstudio's Avatar
Default Anyone know how to adjust the amount of engine braking?
I've tried searching the forums about this topic, but seems no one's talked about this. I think the engine braking characteristics of the outlander is very impressive. Yet, I'm finding many times riding I wish the engine braking wasn't so strong, like just coasting around corners, and many other times. The brakes work very well to compensate for less engine braking. Does anyone know exactly what determines the amount of engine braking that is applied, and maybe someone knows just how to adjust it? Maybe a spring or an adjuster of some kind?
-Rob
Old Oct 21, 2003 | 08:58 PM
HillbillyDS's Avatar
I could be way off here but do you think maybe slowing down the idle a bit might help?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 21, 2003 | 09:23 PM
Flatlander330's Avatar
The engine braking system(EBS) cannot be adjusted, however it can be disabled by removing the one-way clutch mechanism out the primary clutch. It's either an all or nothing situation. There are some specialized tools needed to take the clutch apart. The tools are available from Bomb. I suggest investing in a shop manual, it is available from your dealer.
Old Oct 22, 2003 | 01:03 AM
JSsDS's Avatar
HillbillyDs has the right idea albeit wrong direction. raise the idle a little at a time until you achieve the desired results or a happy medium. I don't know much about CVTs so I can't be much help there.
bikedad3
Jul 2, 2015 02:15 AM
CanadianViking
Feb 16, 2001 11:56 AM
exmxer
Dec 7, 2000 01:29 PM
Ursus
Oct 1, 2000 12:28 PM
jbertch
Nov 6, 1999 07:07 PM
